Structural steel
Find and post help & suggestions for the Component Tools.
Structural steel
Postby lineadombra » Thu Jul 25, 2019 10:32 pm
How do I add a customized structural steel in Component
tipes: say a hollow swction column 200x200mm.?
T.i.a. Leonardo
lineadombra
Re: Structural steel
Postby Grant » Fri Jul 26, 2019 7:27 pm
Hi Leonardo,
You aren't able to currently add components to the Component Tool, however, if you follow the steps below you can achieve a similar result.
1. Draw the desired component, with the correct size & materials, in a new SketchUp model.
2. Select the component then use the PlusSpec BIM Tool to add the product info so it will appear in the takeoff.
3. Save the SketchUp file in a folder on your computer. Note: If you save it to a shared drive, anyone who has access to that drive can also use the component.
Return to Component Tools
