where you can define the wall thickness
Postby Lylyhannah » Mon Jan 21, 2019 6:27 pm
I'm not seeing much in the form of foundation walls in the wall tool...
A simple poured foundation wall where you can define the wall thickness, and perhaps a footing as well. (Similar to how the slab tool works). I see there's a "Block", and "Block core filled", but those walls draw out to 4" thick. How do I draw an 8" block wall, or a 12" thick block wall? What about a solid poured concrete wall? For now, I'm drawing them manually, but what I'm missing is the ability to insert hopper windows where I need them. Am I missing something?
Lylyhannah
Re: where you can define the wall thickness
Postby Zach » Tue Jan 29, 2019 1:39 pm
Good Day Lylyhannah,
Thanks for posting.
Could you please ensure that your are updated to the latest version of PlusSpec (V18.8.0)? To update, please click on the following link (https://plusspec.com/release-notes/), sign in and follow the prompts to install PlusSpec. You update PlusSpec the exact same way as when you installed PlusSpec the first time.
After updating, in the Wall Tool dialog, the 'Single Masonry' wall type was designed to be used for materials like bricks, blocks etc. and the thickness of the wall comes from the materials selected in the 'Materials, Selections & Finishes' section of the dialog. If you want to have different wall thicknesses that are available then they will need to create a material and enter the desired thickness.
Regarding added foundations to walls as you draw, this can be done by going to the 'Manual Overrides' section of the Wall Tool dialog, ticking the option called 'Footing?' and entering the associated values for the footing size & position under the wall.
Could you please try this and let me know how it goes?
Users browsing this forum: Bing [Bot] and 3 guests
