roof plan indicated on floor plan
Postby Max » Fri May 25, 2018 10:50 am
How do i drape the roof plan on my floor plan scene to get it to appear on layout? I had it on the floor plan, but then after a minor mod it disappeared. I guess I have clicked off a layer or something. any help?
Max
Re: roof plan indicated on floor plan
Postby Grant » Fri May 25, 2018 11:19 am
Hi Max,
The layer that the roof plan drape is on is called 'Roof Plan'. If you go to your Layer Manager, make sure it's ticked then update you're scene (make sure you're on the correct scene first) it should appear. Please note that you'll also need guides enabled. To do this go to the 'View' tab across the top of your screen and make sure the 'Guides' option is ticked.
Users browsing this forum: DavinPek, DerikPt, Galenhibe, JerodGrer, Keganlimb, Kevencist and 1 guest
