Window Edit - Architrave
Postby johnclancy78 » Mon May 14, 2018 7:44 pm
Every time I go to edit a window the Architrave/Casing option turns on to 'one side' even if it was previously on 'none'.
I generally want all my windows to have no architrave but I have to continually go back and turn this option to 'none' each time I edit a window. As you can imagine it's a bit tedious.
Any suggestions?
John
johnclancy78
Re: Window Edit - Architrave
Postby Grant » Mon May 21, 2018 5:28 pm
Hi John,
The reason this is happening is the architraves default to a value according to the wall type they are getting put into so that you shouldn't need to remember to adjust the architrave when going from external walls to internal walls and vice versa.
At the moment I don't have any suggestions other than do what you're currently doing. I will take this back to the development team for further discussion and see what can be done.
Return to New Users
Users browsing this forum: Google [Bot] and 0 guests
