BESPOKE WALL
BESPOKE WALL
Postby johnclancy78 » Mon Apr 02, 2018 8:39 am
Is it possible to make a bespoke wall such as the one I have attached. It is 100mm external block, 100mm cavity with 50mm insulation and a 100mm internal block.
John
BESPOKE WALL 2.JPG (85.64 KiB) Viewed 3263 times
BESPOKE WALL 1.JPG (67.06 KiB) Viewed 3263 times
johnclancy78
Re: BESPOKE WALL
Postby Grant » Thu Apr 12, 2018 10:32 am
Hi John,
Currently there isn't an easy way to create the wall type you've shown. However, we are planning on updating the Wall Tool to allow the ability to create your own custom wall types in the future. I believer it'll be sometime later this year.
What I would recommend to try in the meantime is to use the 'Double Masonry' option in the Wall Tool to create the two masonry skins and then use the Wall Surface Tool to add the other skins. Please note that you will need to drawn one wall and/or skin at a time.
Re: BESPOKE WALL
Postby johnclancy78 » Sat Apr 14, 2018 4:39 am
Really looking forward to the new wall tool update.
I'd tried your suggestion, it works, kindof. The windows become awkward to fit etc.
John
johnclancy78
Re: BESPOKE WALL
Postby Andrew » Tue Sep 04, 2018 2:53 pm
I am sorry to say, John, I am the one who said no to this feature, I am yet to be convinced of the viability as it is so unusual and it can be done by drawing the main set of walls, copying and push pulling the walls. The reason I am saying no at this moment is that 99% of construction is covered by what we have available and for us to develop to suit the 1% we will never get to where we are going especially as it is 2 minutes work to use the copy paste, push-pull method. Happy to continue the conversation, you may change my opinion if others agree with you.
Re: BESPOKE WALL
Postby Tim » Thu Jul 11, 2019 3:24 am
Hi Andrew
I'm just starting out with PlusSpec and drawing a cavity wall to this spec is the first thing I am attempting … it's standard construction in UK. Has there been any progress towards customising the wall tool to produce this type of wall? I'm having difficulty drawing this type of wall with the wall tool - I can manage to make the insulation appear as a surface of a composite material but unable to manually push / pull or control its thickness.
Tim
Tim
Return to New Users
