Walls (Loops) will not close
Get help with installation and running PlusSpec here. Please do not post bug reports, feature requests, or suggestion questions here.
Postby TrinityConstruction » Thu Mar 22, 2018 11:26 am
Hi, I just purchased plusspec today. I am running it on a mac using Sketchup 2018 Pro. I cannot get my wall loops to close. I have checked help topics online and followed them and still not working. Any advice?
TrinityConstruction
Re: Walls (Loops) will not close
Postby Grant » Tue Mar 27, 2018 9:48 am
Hi TrinityConstruction,
There are two things I would recommend to try first, which I've explained below.
1. Check that you have guides enabled in your model. To do this go to the menus across the top of your screen (whilst SketchUp is open) and click on the option called 'View', then check that 'Guides' is selected (if not, then select it). This should allow you to click back at the beginning point to close your wall loops.The image below will explain this further.
SketchUp - How To Enable Guides.jpg (38.54 KiB) Viewed 1684 times
2. Do you have Dynamic Components installed & enabled? To check this go to 'Window > Extension Manager' and check that it's toggled to enabled. The image below will explain this further.
SketchUp - Enabling Dynamic Components.jpg (70.66 KiB) Viewed 1684 times
Would you be able to please let me know if either of the above fixed the issue you're having?
Walls Loops will not close
Postby LindaVow » Thu Aug 15, 2019 6:38 am
Thanks for the link That didnt fix the problem, but you are right, the popup doesnt have any js files included. Is that something I did?
Christoph
Image ;-)
LindaVow
Return to Support
