G'day Monument, originally we had the cavity sliding pocket associated with the door, the style and the pelmet yet we removed the frame work for aesthetic reasons namely clashing faces. I just a test just now and noticed due to this the pocket itself is not estimating, well picked up thanks.
We will make sure that this in the next release. Is there a particular brand you would like to see? Corinthian or Hume doors? I also assume you would like the pocket to be labeled the same size as the door. EG 90mm * 820mm Cavity sliding pocket
