BIM Tool: Canceling from the BIM Tool UI doesn't undo ...
Postby JClements » Fri Oct 24, 2014 3:46 pm
When clicking on the BIM tool, the selection is made into a BIM Component; however, if the CANCEL button of the BIM Tool UI is clicked the selected geometry remains a BIM Component.
Shouldn't the CANCEL button undo(explode) the component and restore the selected geometry back to it initial state?
Similarly, if a different layer is input in the BIM Tool UI and that layer is a new layer name, CANCELing doesn't remove the layer.
JClements
Re: BIM Tool: Canceling from the BIM Tool UI doesn't undo ..
Postby Dean » Mon Oct 27, 2014 8:48 am
Hi John,
Yes you are correct, we have noticed this problem and have worked on it. It should be updated in the new release with the cancel button working and exploding the component and removing the layer
Users browsing this forum: No registered users and 6 guests
