Box gutters
Box gutters
Postby StudioAware » Sun Jun 08, 2014 2:03 pm
Hi, do you think that box gutter option will be implemented in the future? I noticed in one of Andrew's videos, he has a detailed model, with a box gutter. If this was not generated by PlusSpec, where is the best place to get a standard box gutter component from?
dp
StudioAware
Re: Box gutters
Postby DanielB » Tue Jun 10, 2014 10:35 am
This option should be available in both the included roof tools. Make sure the option named Gutter Profile is not None.
Re: Box gutters
Postby StudioAware » Sat Jun 14, 2014 11:59 pm
Does this give an option for a box gutter? I can only see standard profile gutters.
Regards,
dp
StudioAware
Re: Box gutters
Postby Daniel » Mon Jun 16, 2014 10:13 am
Hi Dp,
When using the Roof Tool you should be able to select the following gutter profiles as shown in the image below:
The Options are also listed below :
Generic Quad 150 High-Front Gutter
Generic Quad 150 Low-Front Gutter
Generic Quad 175 Gutter
Are these the Box gutter options you are after? or is it a different profile to the profiles listed above?
Thanks!
Dan
Daniel
Re: Box gutters
Postby StudioAware » Thu Sep 04, 2014 10:01 pm
Hi Dan,
Please see the below PlusSpec video for an example box gutter. What was used for the box gutter in this video (or was it simply drawn using standard Sketchup)?
https://www.youtube.com/watch?v=KD-AD-PY2a8
Regards,
dp
StudioAware
Re: Box gutters
Postby Andrew » Tue Oct 14, 2014 7:34 am
HI Drew, I actually drew the box gutter and used the bim tool to quantify. In saying that you can use the existing gutter and open the component and drag drag the edges with the move tool.
Users browsing this forum: Jerodkilt and 3 guests
