Fascia and Gutter
Fascia and Gutter
Postby TheDesignHubQld » Thu Mar 30, 2017 7:36 pm
Can you move fascia independently, seems when i separate the fascia, gutter and soffit sheets, when adjusting a roof to reconfigure to have a zero boundary, i cant move the fascia without all the fascia moving around the perimeter.
Sales l Design l 3D Modeling l Drafting l Estimating l Building Consultants
TheDesignHubQld
Re: Fascia and Gutter
Postby Grant » Fri Mar 31, 2017 9:40 am
Hi TheDesignHubQld,
Yes you can move fascia independently by manually editing the geometry. To do so, double-click on the fascia until you get to the base geometry (there will be a blue dotted hatching by default) and select just the side you want to move, then use the SketchUp Move Tool to move the fascia side to where it needs to go. Please note that any manual edits made to objects created by PlusSpec won't be remembered if you use a PlusSpec tool to edit the geometry again.
Users browsing this forum: No registered users and 5 guests
