Adjusting the plasterboard
Talk about anything here
Postby MylesG » Thu Dec 27, 2018 3:55 pm
Guys,
is there any suggested way to adjust the plasterboard around beams and end of walls?
Can i manually adjust the PB lining near by?
will this affect the take off?
If i adjust the wall will i need to redo the adjustment to the PB lining?
Myles
pb lining.JPG (26.25 KiB) Viewed 1857 times
pb lining 2.JPG (118.93 KiB) Viewed 1857 times
MylesG
Re: Adjusting the plasterboard
Postby Zach » Tue Jan 29, 2019 1:08 pm
Good Day MylesG,
Thanks for your post.
I would recommend to use the Wall Surface Tool. When doing this select a plasterboard material for the 'Surface' field (note: you will probably need to create a material) then select 'None' for the other fields. If you were to manually edit the geometry it may work but unless it's done correctly it may not appear in the takeoff, plus manual edits wouldn't be remembered if the PlusSpec object is edited/redrawn at all using one of the PlusSpec tools.
Could you please try this and let me know how it goes?
Thanks.
Return to General
