Materials
Get help with installation and running PlusSpec here. Please do not post bug reports, feature requests, or suggestion questions here.
Materials
Postby Gerard1969 » Fri Mar 02, 2018 1:20 pm
Hi, When i'm creating a new wall i don't have all the selections of bricks that are available.
How do i rectify this.
Gerard
Gerard1969
Re: Materials
Postby Grant » Fri Mar 02, 2018 3:47 pm
Hi Gerard,
I'm not quite sure what's happened but here's what I recommend to try.
1. Go to the Settings Tool (Extensions > PlusSpec > Settings) and ensure that the 'Material Library' and 'State' (only currently appears for the Australia library) fields have the correct option selected.
2. Sync you materials using the Sync Tool.
If the brick you're after still isn't appearing I would recommend to create a material.
Re: Materials
Postby Gerard1969 » Tue Mar 06, 2018 12:54 pm
Thanks for the reply, your solution solved my problem.
Gerard
Gerard1969
Return to Support
