Doors & Windows in external walls not visible from outside
Postby samromeo » Thu Aug 06, 2015 2:49 pm
When inserting Doors & Windows to external Walls they are not visible
samromeo
Re: Doors & Windows in external walls not visible from outsi
Postby Drew » Thu Aug 06, 2015 3:44 pm
Hi Samromeo,
This should definitely not be happening. My first suggestion would be to try and left click on the wall (where the brick overlaps the window), and then press delete. On very rare occasions, a duplicate wall can be formed from parametric alterations. Or, perhaps you have accidentally copied/drawn twice.
Drew
Postby samromeo » Thu Aug 06, 2015 3:52 pm
This was not the Problem the Drop off was higher than the brick Wall
samromeo
Postby Drew » Thu Aug 06, 2015 3:53 pm
Hi Samromeo,
When you changed the Drop off, did that fix the problem?
Drew
