Another stair option needed
Postby andrewc » Fri May 22, 2015 10:10 am
Fella, attached is a skippy file of another stair option that would be great to see as part of your suite. Its a typical simple stair tread / double stringer for use in industrial situations and many basic applications.
Critical options would be:
Size of stringer
stringer offset from outside of tread.
Other than that it options would be the same as the other types.
Thumbs up!! Go Queensland!!!!!!! :twisted: :twisted: :twisted:
stair type.skp
(1.75 MiB) Downloaded 225 times
andrewc
Re: Another stair option needed
Postby Dean » Fri May 22, 2015 10:51 am
Thank you for your suggestion and it's on the things to do list. You can always edit our stairs that we currently have to suit your job.
Go the BLUES!!!!
Postby andrewc » Fri May 22, 2015 1:55 pm
LOL! Bring it!
Not knowing DC's all that intimately I'd stuffed it up if I went looking to change things....
andrewc
