changing door swing
I have placed an interior door in a wall and am having an issue to change the hinge side and swing. In the tutorial, it suggest this can be done using the interact tool by clicking on the sill plate of the door. However, I can only open and close the door and don’t see any other option to change the swing. I have also noticed that the door cutout didn’t remove the bottom plate. I have attached an image of the door with the bottom plate still showing. Any suggestions?
Hi Dekastner. That is an easy one. Simply click the door symbol at the base of the door to change the swing direction. See image
:dc-interact:
If you click the door, it will open and close
