Exterior Wall Cladding
Postby Steve01 » Fri Aug 04, 2017 8:37 am
I want to lower the sheathing and exterior cladding (Dryvit) to cover the floor joists. I could manually pull the sheathing on each wall face from the subfloor down to the foundation. When I tried the same for the Dryvit, only the white core will pull down and not the green face.
Please let me know how I can drop the Dryvit (including the green face) down to the foundation. As well, is there a more efficient and quicker way to accomplish or does this scenario require manual modification?
Thank you for the help.
PlusSpec Question.JPG (172.1 KiB) Viewed 4866 times
Steve01
Re: Exterior Wall Cladding
Postby Grant » Fri Aug 04, 2017 9:52 am
Hi Steve01,
To lower the external skins what you will need to do is go to the 'Manual Overrides' section of the Wall too and edit the field called 'External Step Down (For Concrete & Joists)'. If you enter a positive number (e.g. 100mm or 4") the wall will drop down, but if you enter a negative number (e.g. -100mm or -4") it will raise the bottom of the skin/wall (this is similar to the top part of the wall with the 'External Drop Off (Positive For Eave, Negative For Parapet)' field).
Currently, the sheathing will always be generated from the same level as the bottom of the frame so if you want to lower the sheathing you'll need to manually edit it in each wall to suit. Please note: I would recommend to only do this once all additions and changes to the wall have been made as any manual edit will be removed if the wall is redrawn (this is the same throughout PlusSpec).
Postby Steve01 » Mon Aug 07, 2017 10:45 pm
Hi Grant,
Thanks for the information, worked perfectly.
Cheers!
Steve01
Postby Grant » Tue Aug 08, 2017 10:00 am
Hi Steve01,
I'm happy to hear that you got the result you were after.
Please let us know if you need any further assistance.
Return to Support
