stud walls
Each time i install a window into a stud wall with cladding i eventually end up having a angle steel lintel protruding from the wall, I click into the item and delete it out of the model as i do with the arrows that sometimes appear after opening a model for the second time.
Is this something I am doing wrong or is it a requirement to go back to the component and switch this off. I have done this on occasions and but the default returns.
I have experienced some unstable commands and insertions with 2015 & 2016.
Tks,
John
Hi John,
The steel lintels should only be appearing for specific wall types (not the cladding wall type). Would you be able to please let me know what version of PlusSpec you’re using?
