by Andrew » Mon Jan 30, 2017 3:33 pm
Note Sketchup 17 has a new easier installer for RBZs, if you are new to Sketchup and PlusSpec I suggest you use the EXE file for Windows. However, if you only have the RBZ you can simply go to Window, Extension manager, and install an RBZ that is compatible. Not all extensions are compatible with Sketchup 16 upwards. You may want to consult with the extension creator or visit the extension warehouse or the PlusSPec download page.
- Attachments
- adding a plugin to Sketchup 17
- Installing an RBZ in Sketchup 17.jpg (247.06 KiB) Viewed 15473 times
