Update Information
Update Information
Postby DanielB » Fri May 09, 2014 4:27 pm
Latest release: v1.3.35 (20th Oct, 2014).
To be notified of new releases, subscribe to this topic.
Latest version can be downloaded from https://buy.plusspec.com/download. Mac/OSX users need to use the RBZ installer (help using the rbz installer).
Code: Select all
>>> Platform Support Table
               Sketchup 8   Sketchup 2013   Sketchup 2014   Sketchup 2015
  Windows      No           No              Yes             Yes
  OSX (Mac)    No           No              Yes             Yes
Windows users should update to the lastest Internet Explorer version available.
This is available from the following link: http://windows.microsoft.com/en-us/inte ... ownload-ie .
To check your current version:
  • Open SketchUp
  • Open Preferences Menu
    • On Windows, this is under the Window menu
    • On Mac/OSX, this is under the SketchUp menu
  • Click Preferences
  • Click the Extensions option
  • Click the PlusSpec option
  • The current version will then be displayed below the extension description.
Minor releases may not be listed here, but the changes will be listed as inclusive in the appropriate patch notes.
:rubysketch: DanielB
DanielB
Re: Update Information
Postby DanielB » Fri May 09, 2014 4:29 pm
(beta) -> v1.2.0 (9th May, 2014)
  • Add: Split Wall
  • Add: Merge Walls
  • Add: Plugin Settings now available in Plugins > PlusSpec > Settings
  • Update: Change TNC/EULA from Beta conditions to release conditions
  • Update: Interactive Tutorial for new tools and layout
  • Update: Default values for tools
  • Update: Various Dynamic Components
  • Update: Some tools will now show status bar messages
  • Update: :wall-tool: alignment can now be changed using the RIGHT key
  • Update: Drawing a slab from face will now make the surface area equal to that fo the face
  • Fix: Launch issues when using SketchUp 2014
  • Fix: Installer will no longer install ruby unless it is needed
  • Fix: Various internal issues
DanielB
Postby DanielB » Fri May 30, 2014 2:41 pm
v1.2.0 -> v1.3.0 (30th May, 2014)
  • Add: :wall-tool: now has basic tooltips
  • Add: New Roof Tool ( :roof-tool3: )
    • Rewritten from scratch
    • Supports split level roofs
    • Old roof tool still available by using the :roof-tool: icon
  • Add: Roof Pitch Tool ( :roof-pitch-tool: )
    • Roof generated using the :roof-tool3: can have the pitch of any face altered
  • Add: USA Package now available
  • Update: Wall dimensions now read left-to-right looking from the outside in :window-tool: and :door-tool:
  • Update: Distribution now contains source for requirements, this should make installation faster
  • Update: Terms and conditions have changed. Check https://buy.plusspec.com/plusspec-prerelease/terms for new terms
  • Fix: Sill timbers will now have the correct orientation
  • Fix: All roof entities will now be layered correctly
  • Fix: Removed redundant message when license is missing
  • Fix: :bim-tool: will now reject characters that will break DC processing
  • Remove: :wall-tool: no longer has bisector override
DanielB
Postby DanielB » Tue Jun 10, 2014 2:45 pm
v1.3.0 -> v1.3.1 (10th June, 2014)
  • Add: OSX (Mac) Support
DanielB
Postby DanielB » Thu Jun 26, 2014 4:34 pm
v1.3.1 -> v1.3.3 (26th June, 2014)
  • Add: Layer Selection option in :bim-tool:
  • Fix: Debug code causing some dialog issues on Windows
  • Fix: Some path issues in OSX
  • Fix: Numerous internal changes
DanielB
Postby DanielB » Wed Jul 02, 2014 5:39 pm
v1.3.4 -> v1.3.5 (3rd July, 2014)
  • Add: More Stair components
  • Add: Generic roof cappings for slate and tile roofs
  • Fix: A number of issues with USA materials
  • Fix: Layering issue with stair components
  • Update: Scene generator layers and styles
DanielB
Postby DanielB » Fri Jul 04, 2014 12:13 pm
v1.3.5 -> v1.3.6 (4th July, 2014)
  • Fix: Roof fascia and capping issues
DanielB
Postby DanielB » Wed Jul 09, 2014 5:17 pm
v1.3.6 -> v1.3.8 (9th July, 2014)
  • Add: version to toolbar (note: removed in v1.3.10)
  • Add: Context menu entries for roofs
  • Add: Context menu entries for windows and doors
  • Add: Fibre Cement
  • Fix: Roof estimation issues
  • Fix: BIM Tool needlessly updating definition name (@JClements)
DanielB
Postby DanielB » Thu Jul 10, 2014 11:37 am
v1.3.8 -> v1.3.9 (10th July, 2014)
  • Fix: Web Dialogs get stuck on "Loading" when using IE 8, 9 and 10
  • Fix: Roofs returning to original position after redraw
DanielB
Postby DanielB » Thu Jul 10, 2014 5:51 pm
v1.3.9 -> v1.3.10 (10th July, 2014)
  • Fix: Toolbar un-docking after updating
DanielB
Next
Return to Support
