SIPS PANELS
Out Now
Moderators: Daniel, Emily
SIPS PANELS
Postby aimejayne » Thu May 25, 2023 12:06 pm
I'm busy creating a new materials to replicate our SIPS wall panels. I'm using the Solid wall type, and than added a 120 x 35mm top wall plate, however I also need a 45 x 120 mm Bottom plate, and there doesn't seem to be a option to add one. What would you suggest? :wall-tool:
Also, I've created a 6mm fiber cement interior cladding and it doesn't show up when the wall is drawn.
And Yes, I did click SUBMIT to update my wall incase that is what you think my error is ;)
My Inputs.PNG (77.83 KiB) Viewed 46 times
FC Missing.PNG (109.83 KiB) Viewed 46 times
aimejayne
Re: SIPS PANELS
Postby Grant » Mon May 29, 2023 4:42 pm
Hi aimejayne,
I would suggest using the Beam Tool to generate the bottom plate. There are a few things to note if you choose this method, which I've listed below.
- Note1: If the wall is to be placed on top of the bottom plate the height of the wall may need to be adjusted to suit.
- Note2: If you do Note1 & need to add doors to the wall, use the "none" option to create a blank opening & draw the door using the Custom Door Tool (this is because the bottom of the wall would be raised up).
- Note3: If the wall is raised all openings will need to be adjusted for this offset.
- Note4: If you want the beam tagged correctly in the takeoff, use the 'Takeoff Tag' field (#4 in below image) to assign the member type. You may need to add an option to the list which can be done via the Import/Export buttons.
Bottom Plate Using PlusDesignBuild Beam Tool.png (49.35 KiB) Viewed 25 times
The visibility of internal linings is off by default so that walls will align when you draw them. To turn them on use the See All tool or generate scenes using the Scene Tool.
See All & Scene Tool in PlusDesignBuild.png (16.43 KiB) Viewed 25 times
Would you be able to let me know if this works for you?
Return to PlusDesignBuild
