quantifying the number of items per Square unit of Measure
Quantifying in a number of items per Unit of measure when doing a BOQ or estimate.
Example #1 Associate or Count the number of bricks per Square measure. This can also be used in concrete or cubic measure, lineal EG fascia gutter or trim, or Square eg tiles or flooring.
quantifying or counting items per unit of measure sqaure, linial, cubic, each in estimating software PlusDesignBuild.jpg
Tip if the item you have is is larger than ONE unit of measure, simply click the two arrows to change see image below. This will save you diving the length by the width to get a decimal of units per square measure
Has the updated framing module changed?, Not seeing the unit Qty total
Hi ConT,
Can you please provide a screenshot of the result you’re getting?
