quantifying the number of items per Square unit of Measure
Find and post help & suggestions for the Takeoff/Estimating Tools.
Postby Andrew » Tue Sep 29, 2020 10:13 am
Quantifying in a number of items per Unit of measure when doing a BOQ or estimate.
Example #1 Associate or Count the number of bricks per Square measure. This can also be used in concrete or cubic measure, lineal EG fascia gutter or trim, or Square eg tiles or flooring.
quantifying or counting items per unit of measure sqaure, linial, cubic, each in estimating software PlusDesignBuild.jpg
This shows how to change the number of bricks per square metre or feet
quantifying or counting items per unit of measure sqaure, linial, cubic, each in estimating software PlusDesignBuild.jpg (500.36 KiB) Viewed 890 times
Tip if the item you have is is larger than ONE unit of measure, simply click the two arrows to change see image below. This will save you diving the length by the width to get a decimal of units per square measure
UOM per sq measure input change when estimating each items from an area
UNITS PER UNIT OF MEASURE OR UNIT OF MEASURE PER UNIT.jpg (351.92 KiB) Viewed 890 times
Return to Takeoff/Estimating Tools
