Wall Tool
Product suggestion and general discussions about the needs pertaining to Australia and New Zealand.
Wall Tool
Postby msnook » Mon Jun 09, 2014 6:56 pm
:wall-tool: Can we have 90mm Brickwork for W. Australia
msnook
Re: Wall Tool
Postby Andrew » Tue Jun 10, 2014 2:03 pm
This should already be done. I'll get @Grant to make sure this is currently available.
Msnook, who is the major brick supplier in WA? Could you put us in contact with them? We will get you a full range.
How are you finding the software?
Re: Wall Tool
Postby msnook » Wed Jun 11, 2014 11:07 am
I sent all details of West Australia Bricks to Aryan 2 weeks ago. Midland Brick is the main manufacture in W.A. witch is part of the Boral Group.The software is brilliant and will save me a lot of time with take off and quant's. Although it took some time to work out how to get Length size and units for a complete timber roof with rafters valleys hips & ridge. thanks Mike
msnook
Re: Wall Tool
Postby StudioAware » Wed Jun 11, 2014 3:59 pm
I agree with msnook, and can confirm his statement regarding the main brick manufacturer. We use a lot of double brick (110mm exterior and 90mm interior), so I would also love to have this wall-type catered for.
Regards,
dp
StudioAware
Re: Wall Tool
Postby msnook » Tue Jun 17, 2014 11:52 am
How soon before we get 90mm brickwork
msnook
Re: Wall Tool
Postby Daniel » Tue Jun 17, 2014 1:14 pm
msnook wrote:How soon before we get 90mm brickwork
Hi MSnook
The 90mm Brickwork + Insulation is looking to be added today - It's currently just being tested.
I will post here as soon as the new version is uploaded.
Daniel
Daniel
Re: Wall Tool
Postby Daniel » Tue Jun 17, 2014 4:15 pm
Hi Guys!
90mm Bricks have been added in the new version.
Download it here :)
https://buy.plusspec.com/download
Dan
Daniel
Re: Wall Tool
Postby msnook » Wed Jun 18, 2014 12:36 pm
Thanks Dan for the 90mm Brickwork. Is there a work around to get the cement render's on the external 90mm Brickwork. Thanks Mike
msnook
Re: Wall Tool
Postby Daniel » Wed Jun 18, 2014 1:58 pm
msnook wrote:Thanks Dan for the 90mm Brickwork. Is there a work around to get the cement render's on the external 90mm Brickwork. Thanks Mike
Hi Mike
We're currently reviewing this - Currently all renders automatically use the 110mm Brick - I'll have an update for you shortly!
Dan
Daniel
Re: Wall Tool
Postby Andrew » Thu Jun 19, 2014 12:53 pm
Hi Guys, I know it sounds like a silly question yet I gather that you guys will want the option to render one side only and also both sides of the wall. I would think that two sides should come up as default and just turn one side off later.
We are also working on paint and finishes, yet it will be a little way off. In Sydney we also use acrylic render over the top of cement render. Do you guys do similar? For retaining walls I think a water proof membrane is required as well?
Do you guys have any textures that you would like added by default for future drawing?
Next
Return to Australia and New Zealand
