Stair Tool
Stair Tool
Postby JBMI » Wed May 04, 2016 10:35 am
Is it not possible to adjust run to less than 240mm?
JBMI
Re: Stair Tool
Postby Dean » Tue May 10, 2016 3:59 pm
Currently it is not possible to adjust the run to less than 240mm. In the future you will be able to.
Re: Stair Tool
Postby zorro » Wed May 11, 2016 8:04 am
If you are using a simple staircase such as one of the "straight" options there is a workaround. Simply use the Sketchup "Scale" tool to horizontally scale the staircase giving you a smaller run.
For example if you require a run of 180mm, place the staircase with the 240mm run, switch to the scale tool and horizontally scale the staircase by 0.75.
You can apply this workaround to one of the "L-Shape" options as well... it is a little more complex in that you need to delve in to the component groups of the staircase and scale those individually. i.e. scale the first flight of steps then scale the second flight etc. You can do this in less than a minute or so.
Hope this is of use.
Zorro
zorro
Re: Stair Tool
Postby JBMI » Thu May 12, 2016 11:55 pm
Thank you
JBMI
Re: Stair Tool
Postby Dean » Fri May 13, 2016 9:26 am
Thank you for the reply Zorro, Great job :)
