Change overhang of a gable
Hi
I have changed a hip roof to a gable and left the standard gable overhang. Later in my drawing I have been told there is no overhang …How do I change this. If I edit roof, it changes them all and if I use roof editing tool it wont pick the gable
Thanks Sam
Hi Sam,
Currently there is no way to change the gable over hang parametric. There are 2 ways you can go about fixing this. This is to either push pull and manually edit your roof or you can easily re-draw your roof.
I would re-draw the roof as it is very simple. I would suggest to delete the roof and then the face will still be there. I would right click the face and generate roof. and then just add the gables again.
ok thanks Dean, I’ll pop that one in the suggestion box :stuck_out_tongue:
aha ok thank you Sam. I will bring it up with the rest of the team. :slight_smile:
