Problem loading PlusSpec with dual monitor setup
Report & get help with crashes here
Postby Rem » Mon Mar 27, 2017 7:30 am
Hi guys, I'm working on a laptop with a secondary screen on HDMI port, as an extended desktop configuration. Sketchup freezes at startup when PlusSpec tries to load.
I have tried with a different secondary screen and that doesn't fix anything.
If I switch to single display there is no problem at all.
Was wondering if anyone has encountered the same problem or if someone would know how to fix it.
Rem
Rem
Re: Problem loading PlusSpec with dual monitor setup
Postby Grant » Tue Mar 28, 2017 10:40 am
Hi Rem,
I believe this might have something to do with the graphics card on your laptop struggling with the second screen.
To check what graphics card you have, please follow the steps below:
1. Go to the 'Control Panel'.
2. Select 'Device Manager'.
3. Select the arrow for 'Display adapters' to expand it and it will show you what your graphics card is.
Would you be able to please let me know what graphics card is installed in your computer?
Postby Rem » Tue Mar 28, 2017 5:40 pm
Hi Grant, this is what I'm running with:
I have done a driver update.
Rem
Postby Rem » Tue Mar 28, 2017 6:17 pm
It boots ok when both screens are in clone mode. It is fine as well when sketchup starts on the laptop screen. For some reason it doesn't like when sketchup and Plusspec start on 2 different screens
Rem
Postby Grant » Fri Mar 31, 2017 4:26 pm
Hi Rem,
I haven't heard of this issue before so I'm not sure what it might be as the graphics cards you have installed should be able to run everything.
What I would recommend to do is to contact SketchUp and see if there is an issue on their side as it doesn't appear to be a PlusSpec related issue.
Would you be able to please let me know if/when you get the issue sorted out? Thank you.
Postby Rem » Sun Apr 02, 2017 8:34 pm
SketchUp starts fine on it's own. The problem is that everything freezes when PlusSpec splash screen tries to load. I just get the empty window of PlusSpec welcome screen. This only happens when sketchup loads on the secondary display and PlusSpec loads on the primary display.
It would probably fix it if I could get PlusSpec to load on the same display as sketchup.
Rem
Postby Andrew » Wed Jun 14, 2017 4:00 pm
Rem did you get this issue sorted out? I assume you contacted the office? I would be interested to find out what the problem was and how efficiently we fixed it. We are always doing our best to make sure you guys can get your work done faster.
Return to Crash Information
