3 way wall joint
3 way wall joint
Postby Arnold » Tue Mar 14, 2017 5:05 pm
These three way wall joints look sort of OK here but the structure isn't quite right. I guess I could shift the studs around in the structure. I had no success trying to meld or join these, is there a way?
3 way wall joint.jpg (147.69 KiB) Viewed 2185 times
Arnold
Re: 3 way wall joint
Postby Grant » Thu Mar 16, 2017 10:38 am
Hi Arnold,
At the moment there isn't a way to meld walls joined together like in the image you provided. What I would recommend to do to get closer to the result you're after is to do what you said and go into the structure of the wall and move the studs around as how you've joined them already is pretty much what we would do as well. Please not that any manual edits will be lost if you edit the wall with a PlusSpec tool.
I would be happy to assist you if you have any further enquiries.
Return to New Users
Users browsing this forum: No registered users and 6 guests
