Cloisons de 7 et 10
Bonjour a vous, Je debute avec Plusspec et je rencontre deja un probleme. Comment faire pour creer des cloisons separative de 7cm ou 10 cm au norme francais.
Definitely I need assistance with the internal walls creation.
For example : I created an internal wall with a 13mm (Gyprock CD Plasterboard) on both sides (French internal walls), choose a color (all the set up are fine) and when I submit, nothing is happening. That is bothering me these past 2 days. Can you tell me if you have a set up for the internal walls that i can use or a tutorial or a webminary for that matter.
Merci
Hi Kimparis,
Thanks for your post.
First make sure you have watched the beginner’s tutorial on how to use the wall tool, see video here: youtu.be/mlyUoJYpAPA
Second, make sure you have your material library synced as per the below steps:
  1. Head to the Job tool :job-tool:
  2. Scroll down to settings and click Set
  3. Select United States from the Material Library Drop Down
  4. Click Submit
Here is a video on how to sync your material library: youtu.be/1OZrgIwUzVs
The double check there are no red fields in the dialogs preventing your from clicking submit and drawing the wall.
Let me know how you go!
Emily
