Window Edit - Architrave
Hi Grant,
Every time I go to edit a window the Architrave/Casing option turns on to ‘one side’ even if it was previously on ‘none’.
I generally want all my windows to have no architrave but I have to continually go back and turn this option to ‘none’ each time I edit a window. As you can imagine it’s a bit tedious.
Any suggestions?
John
Hi John,
The reason this is happening is the architraves default to a value according to the wall type they are getting put into so that you shouldn’t need to remember to adjust the architrave when going from external walls to internal walls and vice versa.
At the moment I don’t have any suggestions other than do what you’re currently doing. I will take this back to the development team for further discussion and see what can be done.
