Joining Different Sized Walls
Postby johnclancy78 » Fri Mar 23, 2018 8:00 am
Odd Walls Before.JPG (87.45 KiB) Viewed 3572 times
Hi Grant,
How do i join these walls together without a triangular chunk being taken from where they meet internally?
Also is it possible to change the material on just the ends or the top of the wall? Or is there a better way to resolve this altogether?
Thanks in advance
John
johnclancy78
Re: Joining Different Sized Walls
Postby Grant » Thu Apr 12, 2018 10:49 am
Hi John,
The way that you've shown in the image is the way to currently remove the triangular chunk where the walls meet by connecting the walls together as a 'butt joint'.
Currently the only way to change the wall top & side materials is to go into the walls and manually apply the materials. Please note if you do this that any manual edits will be removed if/when the wall(s) are redrawn or edited so we recommend to only do manual edits at the end of the job or if no further edits will be made to the wall or other objects.
In the next version (which will be available in the next week or two) the top & ends of walls will have the same material applied to them as the outer material (e.g. if a red brick is on the outside of the wall then the top & ends of that skin will also have a red brick material.
Postby johnclancy78 » Sat Apr 14, 2018 4:20 am
Hi Grant,
Thanks for the reply.
That will be very handy in the next version.
Cheers
John
johnclancy78
