window/doors starting point
Hello ,
I’m on a mac and i can’t use the right arrow key to change the starting point.
Hi Joe,
Currently on Mac’s, to change the starting points when drawing windows & doors, you’ll need to press the Submit button first and then you should be able to use the right arrow key to change the drawing position from pitching point to the internal/external sides of the wall.
Hi Grant,
That’s the solution.
