window rood wall problem
Talk about anything here
Postby MylesG » Thu Apr 06, 2017 12:21 pm
Hey guys
I think this snip explains my problem.
The red straight line is the split in my wall, when i move that split my window dose some funny business.
Also having problems with raked eaves on hip and valley roofs, I don't know if its a bug or just the roof I'm drawing.
Myles
WINDOW ROOF WALL PROBLEM.JPG (54.05 KiB) Viewed 428 times
MylesG
Re: window rood wall problem
Postby Grant » Wed Apr 12, 2017 5:12 pm
Hi Myles,
I believe the issue might be because the window appears to be right up against the wall split and therefore being affected when's it's moved. If this isn't the case, would you be able to please send the model across to support@rubysketch.com?
Regarding the raked eave issue you're having, there currently isn't an option to create a raked eave for the roof tools so you would need to manually edit the eave to create the rake eave. If you send me the model I will have a look at this also. I can let you know that in the next version there has been a lot of updates to the roof tools that will enable you to do things like this.
Return to General
