EDITING WINDOWS AND DOORS
Post any found bugs here.
Postby watkins888 » Thu Aug 04, 2016 6:15 pm
Hi . when i go to edit a window or door in order to change type the system freezes and has to be re started. If i delete window/door and add new one its fine. Any suggestions as to possible issue, does 1001 freeware plug in for sketch up. or Skalp clash with Plus spec.
Regards Paul.
watkins888
Re: EDITING WINDOWS AND DOORS
Postby Grant » Fri Aug 05, 2016 5:53 pm
Hi Paul,
It sounds to me that you've got Outliner open. We strongly recommend that you never have Outliner open when using PlusSpec as it will slow your computer down and most likely make SketchUp crash.
If that doesn't fix the issue would you be able to please take a screenshot of the information that appears in the Ruby Console when the issue occurs? To get this information open the Ruby Console (go to Window > Ruby Console) and then recreate the steps you took to get the issue. If nothing appears I would recommend trying the following and see if that makes any difference when changing windows/doors.
Also, the plugins you mentioned shouldn't be clashing with PlusSpec.
I look forward to hearing back from you.
Return to Bugs
Users browsing this forum: No registered users and 10 guests
