New Material Texture Mismatch
Post any found bugs here.
Postby minimalex » Fri Oct 20, 2017 5:01 am
I'm adapting a double stud wall to exterior, but importing textures has gone weird. Importing the same texture on different wall types (Why can't I import a material once and use it on different walls?) yields different textures in SU. I now have 6 versions of the material in there, non of them match the original imported texture. Sometimes it's inexplicably blue tinted.
minimalex
Re: New Material Texture Mismatch
Postby minimalex » Fri Oct 20, 2017 5:12 am
Screen Shot 2017-10-19 at 11.42.54 AM.png (157.33 KiB) Viewed 2724 times
minimalex
Postby minimalex » Thu Oct 26, 2017 5:53 am
FIXED, sort of. I deleted all the versions of the texture, and recreated it, and got a correct color version to work. Still a mystery, but problem bypassed for now.
minimalex
Postby Grant » Mon Oct 30, 2017 5:08 pm
Hi minimalex,
I'm not quite sure what's happening here. If the issue occurs again, would you be able to please send the model with the issue to support@rubysketch.com so I can have a look at it?
Return to Bugs
