Windows - recalling previous
Post any found bugs here.
Postby andrewc » Tue Jun 23, 2015 2:15 pm
Hi fellas [and sheilas],
When we input a certain window type [I don't know about others], but I tend to go around and insert all 'like components together. I've found that the window dialogue box for both 'Window Class' and 'Architrave' don't recall your previous selection... any chance of having a look at that for me?
See screenshot attached. :P
Cheers,
andrewc
Re: Windows - recalling previous
Postby Dean » Tue Jun 23, 2015 4:25 pm
Hi Andrew,
If you factory reset PlusSpec this will be fixed. It is because you are a user for over a year. A factory reset will not remove anything that you currently use and it is healthy for your system. Follow steps below on how to do this.
1. Go to 'Extensions' (Up the top between 'Window' and 'Help')
2. Go down to 'PlusSpec'
3. Go to the last option called 'Reset Factory Default'
4. Close SketchUp
5. Open SketchUp and your all good to go.
Postby andrewc » Wed Jun 24, 2015 1:57 pm
Cheers, Dean!
Cheers,
andrewc
Postby Dean » Wed Jun 24, 2015 2:48 pm
All good Andrew.
Postby andrewc » Wed Jul 01, 2015 1:49 pm
Dean, I reset as you said to do but the Attributes drop-down [architraves particularly] does recall previous...
Cheers,
andrewc
Postby jwhida » Fri Oct 16, 2015 8:20 am
I am finding the same:
Frame Type: NOT remembered
Class: NOT remembered
Attributes-Architrave: NOT remembered
Attributes-Frame Width: NOT remembered
I did a factory reset
I assume the previous poster meant 'doesn't recall' as that is what I am experiencing
PlusSpec is only extension installed
2.4 GHz Intel Core i7
AMD Radeon HD 6770M 1024 MB
MAC, OSX 10.10.5 (Yosemite)
Sketchup Pro 2015.
jwhida
Postby Dean » Fri Oct 16, 2015 10:01 am
This is fixed for the next version. Sorry that it is not in the current version.
Thank you for the post.
Postby jwhida » Fri Oct 16, 2015 10:35 am
Is that fix for PlusSpec 2016 or an update to 2015 ?
jwhida
Postby Dean » Tue Oct 27, 2015 10:38 am
It is in the next update for PlusSpec 2015
Postby andrewc » Thu Mar 03, 2016 1:58 pm
hi guys, just wondering when this issues will be fixed?
I still find that when inserting windows the dialogue box for both 'Window Class' and 'Architrave' don't recall your previous selection. Always defaults to 'Commercial' and 'One side only' respectively....
Gets really cumbersome when inserting multiple of the same window.
Cheers,
andrewc
Next
Return to Bugs
