Timber/Lumber Stud material problem
Post any found bugs here.
Postby GeoffreyFrance » Wed Aug 30, 2017 12:30 am
:!: :wall-tool: Hello all,
I have problems with materials for stud Timber/Lumber.
It's "Unable to find requested materials".
What can I do ? I created one but I can not use it too.
Thank you so much for your help.
I use Windows 8 with the last version of Sketchup and PlusSpec
:wall-tool: :!:
GeoffreyFrance
Re: Timber/Lumber Stud material problem
Postby Andrew » Mon Sep 04, 2017 9:50 am
It sounds like you need to click the Sync button if you are on a Mac that is the only way to do it. It comes up when you open PlusSpec on the splash screen & it is in the main PLusSpec tool bar at the top. :-)
What size are you trying to create? I assume it is France
Here is a video that will help. https://youtu.be/0bBvAYWXfIo
There are a heap of videos on youtube, Type in "create material PlusSpec" I hope it helps. :-)
Return to Bugs
Users browsing this forum: Bing [Bot] and 1 guest
