north tool - set project north does not work
Hi, I am trying the north tool for the first time (from the scene tool :scene-gen: , not job tool as mentioned in the help video).
I have set the geo location area, and displaying the north axis.
Now trying to set the project north, the dialog disappears, and get a hand pointer,
and the text at the bottom says “Select a point on the map to move to the origin…”
Nothing happens when I click on the map.
Hi Rispa thanks for commenting, I will see if I can get Andew to update that tutorial as that must be an old one that slipped through the gaps.
here is the updated video link to youtu.be/3kFncFom4CE
Thanks for the update, I’ll check out the video.
Aligning North using nearmap tiles worked, but not with the free one (which is the real problem I raised).
The video was good. Thanks!
