When using Masonry walls - no need for timber heads!
Post any found bugs here.
Postby andrewc » Sat Aug 09, 2014 9:46 am
Hey guys, You'll notice that when you draw a wall in blockwork [say 200mm] and add a window your only option is to place a composite head to the lintel rather than just continuing blockwork over. When I choose 'NONE', I can submit those details because PlusSpec is asking me to choose a head.
See attached screenshot.
Cheers,
Andrew [utiler]
Cheers,
andrewc
Re: When using Masonry walls - no need for timber heads!
Postby Daniel » Tue Aug 12, 2014 11:05 am
Hi Andrew,
Thanks for the detailed post regarding this.
I've just tested this and was able to reproduce it - I'll pass it onto the developers and notify you when it is resolved.
Dan
Daniel
Postby andrewc » Wed Sep 10, 2014 5:23 pm
Daniel, has this been looked at yet? Still no option to select [none] for blockwork heads.....
Cheers,
andrewc
Postby Dean » Thu Sep 11, 2014 10:04 am
Hi Andrew,
This has been looked at. In certain wall types where timber frame and timber headers aren't needed, the wall automatically picks up that that a frame and header isn't needed and even if you select a timber it won't appear in your wall. The same goes when quantifying, it also knows that the wall type doesn't need a frame or header and no timber will show.
Being able to select none in the menu is still in progress and will be available before full release.
Thanks again, keep posting :)
Postby andrewc » Thu Sep 11, 2014 1:45 pm
Thanks Dean, I just notice it with masonry blockwork that's all....
Cheers,
andrewc
Postby Dean » Mon Sep 15, 2014 9:03 am
Thats ok Andrew,
Keep posting :)
Postby andrewc » Mon Nov 17, 2014 1:34 pm
Dean wrote:Hi Andrew,
Hi Dean, I notice structural heads are still required when building a block wall..... when do you think it will be amended?
Cheers,
andrewc
Return to Bugs
