Section Hatching in 2019
Post any found bugs here.
Postby Dawson » Thu Mar 07, 2019 5:30 am
it seems like there is something going on with the section hatching. I haven't done a lot of exploring yet, but when I try to place a hatching it makes one big blank field that blocks out everything. Has anyone encountered this yet?
Dawson
Dawson
Re: Section Hatching in 2019
Postby Andrew » Thu Mar 07, 2019 4:54 pm
Screen shot of PlusSpec section cut faces in Sketchup
Section cut face filled textured sections in Sketchup.png (433.7 KiB) Viewed 3588 times
Hello Dawson, I just came across this today myself, I have brought it to the attention of the dev team. Thanks for pointing this out, it appears to be a Sketchup 19 compatibility issue as I just tried running a live section in Sketchup 18 and it works fine.
Hey Dawson, I hope you are using the PlusSpec 19 version, it is 10 times faster. If not, you can get it at the sign-in page, here is the link https://buy.plusspec.com/users/sign_in
Postby Dawson » Sat Sep 21, 2019 6:35 am
Hi there, wondering of there is any word on that hatching tool? I am using version 19.1. I have starting doing my hatching by hand or in Layout which is fine, but Plus spec should be doing it...
Thanks!
Dawson
Postby Grant » Wed Dec 04, 2019 4:11 pm
Hi Dawson,
We are currently making changes in and around the Section Hatching Tool which will be in one of the coming releases. I believe these changes will improve your experience with section hatching & Layout.
Postby Dawson » Wed Feb 19, 2020 2:35 am
HI there,
Just updating to say that I'm still having the section issue. Doing a front section in this case, it just makes a big solid plane that doesn't include the section of the object(s). It doesn't seem to be an issue from every perspective. I'll see if I can narrow it down...
Dawson
Dawson
Postby PaulA » Fri Mar 27, 2020 2:23 pm
I'm also having problems with Section hatching. Seem to constantly get a large grey face appearing within the section plane once I hit "Create section hatching". I end up deleting this face as it obscures the whole model.
Grey face created when applying Section hatching
PaulA
Return to Bugs
