Garage doors facing the wrong way
Postby SamLanglar » Fri Jun 15, 2018 5:33 pm
i am having troubles with my garage doors. Every time I try add one it sits outside not inside. I have drawn the wall correct, I have opened a new drawing, I have tried it on a panel lift, tilt and a roller door and the same thing happens.
Sam
garage doors wrong face.PNG (220.92 KiB) Viewed 2280 times
Cheers Sam
(Windows 8.1/ Sketchup Pro2015/ PlusSPec v16.3.7)
SamLanglar
Re: Garage doors facing the wrong way
Postby Grant » Mon Jun 18, 2018 11:02 am
Hi Sam,
We recently moved the ability to change most of the window & door opening directions to the dialog under a field called 'Opening Direction' (except for any swinging door which you'll still need to click the door swing plan). If you go the the 'Edit Window/Door Tool' and click on the garage doors it should say 'External' in the 'Opening Direction' field. If you change this to 'Internal' it should fix the issue you're having.
Note: The options in this field may change when changing from door to door or from window to window, so before you submit the window or door I'd recommend to check this field to save you coming back and changing it.
Postby SamLanglar » Mon Jun 18, 2018 2:33 pm
OH, thanks..sorry I didnt even think to look for an opening direction on a garage door!! All good :)
Cheers Sam
SamLanglar
Postby Andrew » Tue Sep 04, 2018 2:40 pm
I did the same thing, @Grant can you please change this by default to automatically be inside. Although I just built my own Man cave and I needed it outside so it is good to have the option.
