GUTTER BUG WITH SKILLION ROOF
Post any found bugs here.
Postby MylesG » Sun Mar 04, 2018 12:09 pm
Hi Guys
The skillion roof tool has stopped giving me gutters. I have no overhang but gutters selected.
I have attached a screen shot.
Myles
no gutter.JPG (74.99 KiB) Viewed 1743 times
MylesG
Re: GUTTER BUG WITH SKILLION ROOF
Postby Grant » Mon Mar 05, 2018 10:31 am
Hi Myles,
I have just checked this and there appears to be an error in the tool. Thank you for bringing this to our attention, I have just passed it onto the development team to look into.
There is a way that you can easily get around it which is to toggle the overhang on/off using the 'Ctrl' button when drawing the roof. This will then either use the measurement entered for the overhang or disregard it and make it 0 depending on whether Ctrl has bee pressed or not (the line when drawing the roof will go bold and the text near the cursor will change to show this). If you do this for all the sides it should fix the issue.
Postby MylesG » Tue Mar 06, 2018 10:25 am
I'm still having problems with the tool even when using the CTRL function,
MylesG
Postby Grant » Tue Mar 06, 2018 1:17 pm
Hi Myles,
I'm not quite sure what's happening as the Ctrl worked for me.
Another way to get the result you're after is to use the Hip Roof Tool and then use the Edit Roof Pitch/Gable Tool to change three of the sides (the ones that are against the walls) to a gable/90 degrees.
Return to Bugs
