split wall tool
split wall tool
Postby MylesG » Thu Jul 06, 2017 10:53 am
Hi guys just found this with the split wall tool, it removed the opening on other walls and extended the studs
i sorta fixed it on the other wall by melding the wall back together, it still kept the split.
the photo isnt the best but it sorta explains.
thanks
myles
split wall tool.JPG (70.04 KiB) Viewed 2855 times
MylesG
Re: split wall tool
Postby Grant » Tue Jul 11, 2017 4:22 pm
Hi Myles,
I haven't been able to replicate the issue you're having so I have a few of questions.
1. Can you replicate this over and over as well as in different models or does it just happen?
2. Does anything come up in the Ruby Console (go to 'Window > Ruby Console' and recreate the steps)?
3. What was the exact process you took to get this issue to occur?
Also, would you be able to send the model across to support@rubysketch.com so that I can have a look at it? This might help shed some light on the issue.
