Edit Window - Not responding
Post any found bugs here.
Postby SketchHouse » Wed Feb 07, 2018 9:55 pm
Trying to edit a 1200 high sliding/gliding window to 1800 high. I hit submit and Outliner tray starts flashing for 30 secs, plusspec goes into not responding and just hangs. re-start sketchup. repeat. happens again
everytime i add a window, sketchup goes to not responding for 20 secs before fixing itself and installing window.
SketchHouse
Re: Edit Window - Not responding
Postby Grant » Thu Feb 08, 2018 2:53 pm
Hi SketchHouse,
We strongly recommend to always have the Outliner closed until it's really needed as it's always checking your model and updating itself whenever there's an update, which slows your computer down.
Would you be able to please let me know if this fixes the issue yo're having?
Postby tonyp » Sun Apr 29, 2018 1:44 am
When i attempt to modify a window or door, the Plus Spc dialog box takes forever to load all parameters. I also attempted to use the Command Key to select more than one window to edit and that does not work. (Mac)
Screen Shot 2018-04-28 at 9.06.39 AM.png (149.56 KiB) Viewed 4189 times
tonyp
Postby Grant » Mon May 07, 2018 5:12 pm
Hi tonyp,
I'm not sure why this issue is happening. Are you using the latest version (v18.2)?
Return to Bugs
