recess/ledge tool remove
Postby MylesG » Mon Jul 03, 2017 11:47 am
Hi Guys
Using the new remove ledge/recess tool, but the recess is still showing.
Myles
MylesG
Re: recess/ledge tool remove
Postby Grant » Mon Jul 03, 2017 12:45 pm
Hi Myles,
I'm not quite sure where this issue is occurring. Can you please send a screenshot of the result you're getting and the result you are trying to get?
Postby MylesG » Mon Jul 03, 2017 12:52 pm
I'm trying to remove the ledge around my slab, one have of my slab needs the ledge for bricks but the other half just has cladding.
Myles
MylesG
Postby Grant » Thu Jul 06, 2017 10:59 am
Hi Myles,
If you're drawing the slab from points you can press the 'Ctrl' key and it will toggle the recess/ledge. This feature was only just added in PlusSpec 17.
If you've already drawn the slab or created it from a face, I would recommend to use the Void Tool (right-click on the slab and select '+ SLAB > Void Tool > Add Void') on the recess/ledge you want to remove.
