wall duplicating
Occasionally I edit a wall for the external masonry or cladding wall I get a duplicate of the wall, 1 with the edit and then the original wall behind it.
For the masonry wall when I edit it I get the duplicate then it explodes the walls while leaving the original wall exploded as well. any windows or doors then get grouped as well.
Myles
Hi Myles,
It sounds like you’ve make the walls into components without making the second one unique. To fix this, right-click on one of the components and select ‘Make Unique’ from the menu.
If this isn’t the case, can you please send the model to support@rubysketch.com so I can have a look at it?
Plus Spec team
You have spam on the forum
Ian Cleland
Hi Ian,
Thank you for bringing this to our attention.
As soon as we see spam we try to remove it. If you find any spam you can report it by hovering over the spam message and click on the exclamation symbol that appears. This will help speed up the time taken for us to take it down.
