Section hatching
Section hatching
Postby Trev » Thu May 04, 2017 8:54 am
Just learnt that if you group your model your section hatching does not work, after trying many things i realized i grouped the model. I exploded and un grouped and the section hatching worked as usual.. I have also had trouble when i played around with the active cut, this can also impact the section hatching...
Just observations..Trev
Trev
Re: Section hatching
Postby Grant » Thu May 04, 2017 3:50 pm
Hi Trev,
In the current version the Section Hatching Tool won't work through groups or components but in the next version you will be able to. The next version should only be a couple of weeks away.
When you were playing around with the active section what were the steps you took and what was the result?
