Change of external wall type above and below gable roofline
Postby dsimpf » Thu Mar 17, 2016 4:49 pm
Hi
I have a wall that rises internally through ground level and then has a gable roof on outside and first floor rooms inside. Below the gable roof I want the wall to be brick veneer (frame inside, concrete block "outside"). Above the gable roof I want the wall to be brick veneer again but comprising frame inside and brick outside. I assume I need to create two walls. The lower wall is a normal gable wall. However the upper wall needs to have a gable base. How do I do this?
Many thanks.
dsimpf
Re: Change of external wall type above and below gable roofl
Postby dsimpf » Thu Mar 24, 2016 6:04 am
Any thoughts?
dsimpf
Postby Dean » Thu Mar 24, 2016 12:45 pm
Very sorry but I am finding this quite hard to visualise. Could you please send a few screen captures or representations of what you are trying to achieve.
Users browsing this forum: Google [Bot] and 7 guests
