Wall questions
Wall questions
Postby simsmt » Wed Mar 11, 2015 10:25 pm
So my walls are not showing gypboad or anything else. also when a door is put into a wall the bottom plate is not cut out.
attached is my project that I'm working on.
any help on this would be great.
Mark
simsmt
Re: Wall questions
Postby Andrew » Thu May 07, 2015 5:28 pm
Hi Sims it sounds as though your layer are turn off and on according to the way you want to view your model. Simply go to your layers menu in Skethcup and select the way you want to view your model. The reason why we do ot cut out door frames is because you or the builder will actually need to buy this timber to be able to construct the project.
The best tip I can give is to use the scene creator :scene-gen: and use the scenes as they will do this for you automatically.
Good question mate.
