Stairs
How do you adjust the position of stairs??
It seems I cannot move it directly up or down. Ive looked at the tutorial but it does not clearly explain this.
This can be done quite easily, Check out the screen capture below for more information.
You can also find the Axis you want and type in a measurement (eg, 2000mm) and press enter and the stairs will move 2000mm along that Axis.
Hope this helps, if answered incorrectly or more information needed just reply and let me know :slight_smile:
