How to clean this up?
Postby Myles02 » Tue Jan 07, 2020 11:45 am
I need this double wall for the type and size of the G.James door I am going to use.
How can I clean up my model so this looks correct as my 2D drawings?
Myles
double wall.JPG (84.14 KiB) Viewed 4355 times
Myles02
Re: How to clean this up?
Postby Grant » Fri Jan 31, 2020 4:56 pm
Hi Myles,
What I would suggest doing is either of the following:
1) Manually edit the internal skin so that it connects as you need it to.
2) Align the inner skin (i.e. frame) together in one of the below options (see attached image), then manually edit the outer skin so that it lines on in the correct position.
Please note that any manual edits will be reverted to the default state if the wall is redrawn or edited.
Would you be able to let me know if this works for you?
Wall Tool - Wall Connection.jpg (77.55 KiB) Viewed 4193 times
Postby Andrew » Tue Jun 23, 2020 11:20 am
This video shows another method that probably works better, it also goes through what Grant is saying above https://youtu.be/Ocrv1OEg0oQ
